High revs
- Learner Driver
High revs
Looked at an ND for the first time and when started from cold it was running on high revs with a green thermometer icon on the dash. The owner said that this is normal and revs drop back when the icon goes out. My question is Is this normal?
Re: High revs
how high revs are you talking?
for most cars (cant say specifically for the ND) they'll idle a few hundred rpm higher until warmed up.
But if it's starting then revving to 2k it's probably got an issue.
- Learner Driver
Re: High revs
I would have to check but is the green icon normal?
- Vehicle: Non MX-5
Re: High revs
google "mx5 nd owner manual" and start reading. i'm sure you'll find the answer quicker than awaiting a response on a forum.
- greenMachine
Re: High revs
Wash your mouth out PRR
Read the manual indeed, whoever heard of such a thing ...
. Next thing you will be telling people about the search function - way to get a ban
Re: High revs
Bloggsy wrote: My question is Is this normal?
Yep, normal behavior.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
- Learner Driver
Re: High revs
Excellent thank you for the reply
- Roadrunner
- coyotes after you
Re: High revs
Yep it's normal and usually sounds horrible too for the 60 seconds it takes to warm up.
My CX5 Diesel does the same thing.
MeepMeep
- bruce
- Vehicle: NA8 - Turbo
- StanTheMan
Re: High revs
Diesel should be banned for private use
Sent from my SM-G935F using Tapatalk
- StanTheMan
Re: High revs
But then
Why should business get all the benfit?
- Roadrunner
- coyotes after you
Re: High revs
I was just saying my ND also does the high rev thing on warm up, as does my CX5 (and almost all modern cars).
And I'll take my Diesel CX5 for towing my track MX-5 between 2-5 hours down the highway once a month any day over a petrol version thanks
MeepMeep
- Vehicle: Non MX-5
Re: High revs
When it is turned off.bruce wrote:When does a diesel sound good?! Ha!
