Recommendation for sandwich plate, oil filter relocation, and position for said relocation - NB
systmoveride
Postby systmoveride » Wed Nov 07, 2018 4:04 pm
Hey all, in the market for a good oil filter relocation kit, and where abouts I can mount it on the NB.
Ideally looking for something that can have an oil pressure sender attached to it as well, otherwise also looking to invest in a good sandwich plate that I can use for oil pressure and/or temp (still undecided on temp at this point as I already have water temp), and eventually run an oil cooler off of.
Any brands or kits you'd recommend would be greatly appreciated! :D
Luke
Re: Recommendation for sandwich plate, oil filter relocation, and position for said relocation - NB
Postby Luke » Thu Nov 22, 2018 5:43 pm
If you want neat, tidy and factory looking this is the kit you want.
http://www.thompson-automotive.com/relocation.html
It uses a existing hole that is threaded in a NB for fitment. Only 1 other hole to drill for NB8B. NB8A no drilling as 2nd hole is already there.
It sits behind the right hand side headlight.
I have had mine in for years, with no signs of leakage with plenty of track use.
It does not meet your requirement of having a oil pressure sender.
It does have a port for oil temperature.
And the site always says no stock. Email them.
2022 BRZ 10AE
2021 GR Yaris
Postby KevGoat » Thu Nov 22, 2018 6:39 pm
I emailed them a couple of times ages ago (last year) but never received a reply. I seem to recall someone on here a few months ago saying these kits aren't available anymore. Shame because they always appeared good quality and had good reviews.
