Toda 256/9mm camshaft timing specs
3gress
Postby 3gress » Fri Jun 22, 2018 12:24 pm
Now armed with the tools to find true TDC and having to adjust cam timing due to significant head shave, i cannot find the correct timing specs to adjust the toda cams back to centre before tuning.
Can anyone provide the timing specs that are provided with camshafts?
Toda have not responded to previous emails and i acquired the cams second hand from project.r a while back without the timing card.
Any info or links would be appreciated, thanks.
Re: Toda 256/9mm camshaft timing specs
Postby NitroDann » Fri Jun 22, 2018 12:36 pm
The correct timing depends on what shaped power curve you have, just get your tuner to dial them using real relevant data, torque/hp at the wheels.
project.r.racing
Postby project.r.racing » Fri Jun 22, 2018 12:41 pm
You dont get old skool timing cards dealing with twin cams, BP engine isn't an old rocker style single cam big block. You dial them in the way you want them. Did you buy them with the cam wheels also? I forget. Just install them as you would a stocko set of cams and then adjust as dann said.
3gress
Postby 3gress » Fri Jun 22, 2018 12:52 pm
Yeah, i picked up the cam gears also. Now running fidanza cam gears.
When i checked clearance by putty on the pistons, the cam gears were dialed through 6 degrees advance and retard to check range of clearance with no issues. I'd like to set cams to original specs and street tune a decent base map to limit dyno time.
3gress
Postby 3gress » Fri Jun 22, 2018 3:24 pm
For reference here is the specs Toda sent in their reply moments ago.
project.r.racing
Postby project.r.racing » Sun Jun 24, 2018 1:56 pm
Good you got the info from them.
Users browsing this forum: Bing [Bot] and 13 guests
