Radiator Replacement
Stral
Postby Stral » Tue Jun 19, 2018 11:19 pm
I have a 1995 NA8 that needs a new radiator, any recommendations on replacement, I am located in Melbourne.
Many thanks
Re: Radiator Replacement
Postby 93_Clubman » Wed Jun 20, 2018 10:37 am
Do you want recommendations on a replacement rad, or recommendations on someone to replace a rad, or both?
Postby Magpie » Wed Jun 20, 2018 12:02 pm
PWR water/oil combo as a replacement.
ImageNew Engine Bay by Eipeip, on Flickr
StanTheMan
Postby StanTheMan » Wed Jun 20, 2018 1:03 pm
where is all your wiring....
LiteIsRite
Postby LiteIsRite » Wed Jun 20, 2018 2:29 pm
If your car is stock, I can't think of a reason to replace with other than the stock OEM equivalent. I've been looking into this myself as mine will need replacement before summer. I plan on buying one of these - https://www.ebay.com.au/itm/MAZDA-MX5-NA-1-6ltr-1-8ltr-1989-1997-MANUAL-RADIATOR-KOYO-QUALITY-/322049824026.
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
Postby bruce » Wed Jun 20, 2018 3:36 pm
That Koyo rad looks good.
apsilon
Postby apsilon » Wed Jun 20, 2018 3:56 pm
LiteIsRite wrote:If your car is stock, I can't think of a reason to replace with other than the stock OEM equivalent. I've been looking into this myself as mine will need replacement before summer. I plan on buying one of these - https://www.ebay.com.au/itm/MAZDA-MX5-NA-1-6ltr-1-8ltr-1989-1997-MANUAL-RADIATOR-KOYO-QUALITY-/322049824026.
I think that may be what's in mine or at least it's branded Koyorad so won't be too different. Looks very OEM though I know it isn't original. MX5 Mania apparently recommended the previous owner change it as the tank was the typical very brown colour they go before failing so it was replaced along with all water hoses.
'97 Neo Green limited edition
Stral
Postby Stral » Thu Jun 21, 2018 12:35 am
93_Clubman wrote:Do you want recommendations on a replacement rad, or recommendations on someone to replace a rad, or both?
Both. Thank you.
Car is stock.
Postby 93_Clubman » Thu Jun 21, 2018 11:49 am
If in far southeast, for anything MX5: Gerald & Chaz @ Mammi Motors, 10 Industrial Drv, Somerville, 5977 7973. Otherwise any good mechanic or radiator shop.
Following is a popular replacement:
Alternatively, some go for an ASI 42mm (52mm not required for standard MX5) full aluminum rad:
https://www.ebay.com.au/itm/Aluminum-Ra ... SwCU1Yr8~N
DTH
Postby DTH » Sun Jul 22, 2018 1:08 pm
I bought the ASI 42mm rad from ebay over a year ago and it's been great and very reasonable price.
Stral
Postby Stral » Sun Jul 22, 2018 1:09 pm
DTH wrote:I bought the ASI 42mm rad from ebay over a year ago and it's been great and very reasonable price.
Thank you
