Fuel fex sensor mounting location
StanTheMan
Postby StanTheMan » Sun Jun 10, 2018 6:40 pm
there isnt much room to bolt it down on the drivers side.
they do suggest to have it near the fuel rail.
I have seen it mounted near the fuel tanlk on the return line but thats a fair way from the Action
any suggestion?
pics would be awesome
Re: Fuel fex sensor mounting location
Postby NitroDann » Sun Jun 10, 2018 6:50 pm
If youve seen the rate at which your fuel system cycles and you consider the fuel in the tank is being splashed in at a high rate by the pump and therefor mixing quite a bit, you can probably justify the rear position above the fuel filter. That's what we have always done. That's how I justify it anyway, and the results have been good. Just fill the tank with the new fuel from close to empty where possible and then drive it sensibly for a few hundred metres.
Easy.
StanTheMan
Postby StanTheMan » Sun Jun 10, 2018 7:23 pm
OK thanks Dann.
Thats probably what I'll do then. ...saves the hassle of getting another wire through the firewall.
