NC 2.0 to 2.5 swap
NC 2.0 to 2.5 swap
Hi Guys,
Looking at swapping out my 2.0 for a 2.5 in my NC prod sports racecar.
Can anyone give me a idea on budget required to do the swap?
I’ve noticed a few donor engines for $800-1500 on eBay.
I already have supporting mods currently fitted to my 2.0 but would look at the EcuTek software for tuning.
Cheers!
Cheers!
- bruce
- Vehicle: NA8 - Turbo
Re: NC 2.0 to 2.5 swap
Boyracer recently advertised and sold such a race car - you missed it.
There's also a recent-ish thread about a guy who did it to his street car (first two engines he got were duds). Clubman93 (the Oracle of Info) will know where that is...
bruce wrote:also a recent-ish thread about a guy who did it to his street car
viewtopic.php?f=79&t=67063
And IIRC, Nuddy has also done it even more recently, but not sure if he's provided detail: viewtopic.php?f=57&t=75248
- bruce
- Regie
- Vehicle: NC - V8
if you can swing a spanner you be able to do it cheap.
If not, some people have payed around $8K for the conversion
Thanks for the info guys.
$8000 fitted seems a lot for what is essentially labour only and the engine is a drop in.
This is what I am trying to work out....
If a engine is say $1200 surly there is not $7000 in labour??
- NitroDann
You ever built an engine and put it in the wrong car and tuned it up all running perfect and warrantied it before, right before paying the rent power insurance and the tax man? It adds up.
- bruce
$1200 sounds too cheap for a good engine.The first guy who did it got two dud engines initially, only discovered after installation (multiple engine removals required).
- Custardtart
Guys I’m about to go through this. I paid $500 for an alleged 50k km engine - I’m feeling worried
Anyone got a parts and suppliers list? I already have an upgraded header and a new clutch on the 2.0.
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
- Regie
- Vehicle: NC - V8
- Custardtart
Regie wrote:search and you will find
Thanks Regie, i saw that and whilst it’s a good list I was hoping there might be some local Aussie suppliers.
I’m assuming you can use the 2.0l ecu?
Appreciate that the ECU-tek tune does give a lot of HP but it’s also not cheap.
Lakeside 62.3
Lakeside 62.3
- Regie
- Vehicle: NC - V8
2.0l ECU can be used, buy you WILL need to have it tuned for the 2.5. So factor in $1K max for licence, tune, cable etc etc
- bruce
If u Engineer it add a minimumn $1000 (or easily double that).
- Custardtart
bruce wrote:If u Engineer it add a minimumn $1000 (or easily double that).
Having had a look at the Qld transport website it looks like this engine swap doesn’t need engineering.
Lakeside 62.3
Lakeside 62.3
- bruce
Ah, Qld, anything goes! Just a cheap mod plate maybe?
