Electrolosis Q's
Posted: Fri Jan 19, 2018 7:56 pm
I have a mishimoto radiator with welded AN bungs and nylon braided stainless hose to the electric water pump setup. Also the (brass?) temperature sensors for ewp controller and adaptronic are fitted into rad top tank.
I am concerned about the dissimilar metals causing electrolosis issues and possibly stray currents going through the braided lines as they have a stainless braided inner layer that may make contact at the hose end fittings.
Researching the topic only causes confusion with some suggesting grounding the rad, others advising to isolate it and do the usual stray current tests along with alot of conflicting opinions.
I was planning on fitting a zinc sacrificial anode as a stop-gap measure but would like to ask for thoughts on the matter.
Another issue is the standard temp sensor for the dash gauge grounds through the sensor body and initial plans were to fit this direct to radiator top tank also.
With the reverse flow coolant setup i cannot use the fittings available in the head to mount sensors for accurate temperature measurement and finding somewhere to mount the three needed temperature sensors is a big problem at present.
Thoughts?
Thoughts?
