NB8B AC Compressor Pulley Bearing
mmxx55
Postby mmxx55 » Sun Jan 07, 2018 9:22 am
Hi all,
Does anyone have a part number or spec for the AC compressor pulley bearing? Mine has buggered itself so looking at a bearing changeover rather than a full replacement compressor. AC is still ice cold and the clutch is free of play.
Thanks
Kevin
Sent from my Pixel XL using Tapatalk
Re: NB8B AC Compressor Pulley Bearing
Postby manga_blue » Sun Jan 07, 2018 9:44 am
Mazda only list the whole compressor assembly and the front clutch kit as replaceable parts. So it looks like it needs to be an aftermarket adaptation. Personally I would take it to an engineering workshop to get a new one cut or pressed in.
Else just buy a second hand one from someone here. Failures aren't that common.
mmxx55
Postby mmxx55 » Sun Jan 07, 2018 10:37 am
Thanks Manga Blue
Do you know where I can find part numbers? Is there a catalogue for the whole car somewhere?
Was thinking aftermarket may be the go and was only trying to reduce the downtime.
Postby manga_blue » Sun Jan 07, 2018 11:39 am
Try here and let me know if the 2 new links work.
http://mx5cartalk.com/forum/viewtopic.php?f=76&t=72508&p=924871#p924871
Postby 93_Clubman » Sun Jan 07, 2018 11:43 am
Here's a US online version showing available part numbers for compressor components as indicated by manga_blue: https://www.jimellismazdaparts.com/show ... gory=20231
mmxx55
Postby mmxx55 » Sun Jan 07, 2018 2:50 pm
Thank you all. That works a treat. Looks like pulley and bearing can be purchased together, but at $260 I'll probably go and source a local bearing.
Kevin
mmxx55
Postby mmxx55 » Sun Jan 07, 2018 10:54 pm
For everyone else's reference and my own:
AC Compressor Pulley Bearing Spec: 6001DU5 NSK Japan
From my research, 6001 DDU bearings should be comparable. The DU5 refers to the type of seal present on the bearing.
Other useful tip:
In order to remove the AC clutch without the need of the SST, I cable tied a 1/2" drive to the front swaybar and attached a 14mm socket. The socket was then placed over the centre nut of the clutch.
I then removed the air intake line and used a piece of drift wood with a hammer to crack open the nut but turning the clutch in the tightening direction.
