From what I've found it appears that the fan on the passenger side is the normal engine fan - even though that's adjacent to the AC fan relay - and the fan furthest from the AC fan relay is actually the AC fan...
The car was originally designed the USA as a LHD. Mazda in Japan did the conversion to RHD, presumably on a shoestring budget.
SKYHI wrote:So just to clarify, the fan on the drivers side of our NB/SEs is the AC fan, and the fan on the passengers side is the cooling fan?
Now that I've removed the AC equipment in the engine bay of my SE, I'm considering either removing the AC fan as well, or wiring it up to a switch on the dash, so that I can run it for a few minutes in the pits after each time attack session.
Lokiel wrote:SKYHI wrote:So just to clarify, the fan on the drivers side of our NB/SEs is the AC fan, and the fan on the passengers side is the cooling fan?
Yep and yep (ie. good idea to keep as an extra fan for the pits).
