SE oil pump standard spec
Hi all, anyone know if the original SE oil pump has the extra capacity to operate VVT mechanism? I will rebore my '99 BP block and fit a VVT head, utilising the VVT function of Megasquirt 3. Thanks.
Re: SE oil pump standard spec
From memory the vvt oil pump had better (thicker, more robust) gears and an improved pressure relief valve orifice.
Sorry i cannot comment on whether the SE pump was the improved type or not. If you can provide a pic of the oil pump innards you intend to use i can verify which type it is.
- NitroDann
SE has VVT pump. It is a higher flow design than earlier pumps as has been mentioned.
