NB8B lower clutch controller squeak?
aviper4u
Postby aviper4u » Sun Oct 15, 2017 3:20 pm
hello,
i have noticed this intermittent squeak when disengaging the clutch ie; pressing on the clutch pedal at the end of the travel
it seems to be coming from the lower clutch controller though spraying INOX on it makes it go away but not for long...
i have a bad and short video below if interested...
https://vimeo.com/238243904
should i just ignore or is it the start of something more problematic
the clutch fluid reservoir level is all good :)
thanks guys
1600Dave
Re: NB8B lower clutch controller squeak?
Postby 1600Dave » Sun Oct 15, 2017 6:15 pm
To do a proper job, undo the two bolts holding the slave cylinder onto the gearbox, grease the end of the pushrod where it operates on the clutch throwout lever and re-assemble. I use a white lithium based grease, should last a bit longer than INOX.
Not really a problem, just annoying.
aviper4u
Postby aviper4u » Sun Oct 15, 2017 8:57 pm
Thanks for the tip
Yea I put inox as I always thought it did not damage rubber seals as everyone would say... Oh yea it's a squeak just put some wd40 on it
If I can get a hold of a proper jack I'll go at it with grease next weekend
aviper4u
Postby aviper4u » Tue Oct 31, 2017 8:53 pm
well i greased the clutch controller up well though the problem continues to come and go
i guess i will just live with it
thanks for the help anyway guys
Postby 93_Clubman » Wed Nov 01, 2017 9:02 am
aviper4u wrote:i have noticed this intermittent squeak when disengaging the clutch ie; pressing on the clutch pedal at the end of the travel
aviper4u wrote:well i greased the clutch controller up well though the problem continues to come and go
Given above, might be the thrust or spigot/pilot bearings just starting to go - noise will eventually get worse if this.
aviper4u
Postby aviper4u » Fri Nov 03, 2017 9:50 am
can this be heard if the engine is NOT running?
Postby manga_blue » Fri Nov 03, 2017 10:39 am
No. The thrust bearing only squeals when it's pushed against the clutch on a turning engine. The clutch doesn't have to be fully disengaged for the thrust bearing to squeal, just a slight depression of the clutch pedal is usually enough to cause it. On the other hand the spigot bearing only squeals or grinds when the clutch is fully disengaged and the engine is turning.
So it follows that if the engine is switched off and there's still a noise from the clutch then it's in the linkage somewhere, not the thrust or spigot bearings.
Postby 93_Clubman » Fri Nov 03, 2017 10:59 am
Agree - in linkage/mechanism somewhere, but not the bearings if present when engine not running.
aviper4u
Postby aviper4u » Sun Nov 05, 2017 6:04 pm
thanks for the info guys
noise has stopped again though prolly because of the high humidity this weekend in sydney?
anyways thanks again
