Skunk Ultra Street Mazda NA/NB Intake Manifold
- Alex 2550
hi everyone,
Skunk2 now have an inlet manifold for us.
not sure if many people know about this but also just as a interest thing i thought i would throw it up.
https://skunk2.com/na-nb-mazda-miata-ul ... ifold.html
Retro NA8
build viewtopic.php?f=57&t=71923
Re: Skunk Ultra Street Mazda NA/NB Intake Manifold
Interesting, but noticing they don't list which engine or head its for, and the fitment section is blank.
Apart from the B6 and BP differences, there's also the BP high and low port heads to contend with.
- ManiacLachy
- Engaged
General consensus I've been reading is wait for Trackspeed and 949 to do some testing and comparisons, between them they're going to swap it out against a few different intake manifolds on N/A and turbo cars.
I believe it should fit all 1.8's.
Oddly, the manifold has a 70mm opening for the throttle body, but Skunk 2's throttle body is 64mm
Maybe they'll release a 70mm in time (and hopefully address the issues from the 64mm).
- Alex 2550
one site i read said that its for the BP05 only but skunk2 list it as NA and NB so we will see.
interested in seeing what it does next to the NB8B flat top manifold which they didn't get in the U.S and get very excited over.
i have a flat top manifold for my build and can't say i would go selling it to upgrade to one of these because if it is better it won't be night and day better.
however in the U.S where flat tops are harder to get i can see a market for them and thats my thought on why they built it, not as a full race manifold but as an option over the flat top.
Retro NA8
- Vehicle: Non MX-5
Clearly not for a B6 just by looking at it. You can see there is no cutout for the injectors like a B6 manifold has.hks_kansei wrote:Apart from the B6 and BP differences, there's also the BP high and low port heads to contend with.
Also the double bolt holes suggest it is both of a BP-ZE and BP-4W. The 4W having the wider bolt pattern.
I think the double bolt holes look more like BP05 vs BP4W/BP-VE mounting options. In any case it looks pretty much the same shape as an NA8 manifold. Maybe you could do just as well tidying up one of those instead.
edit:corrected BP-ZE to BP-VE
- NitroDann
Its true that the NA8 manifold is a very very good design already. It needs an adaptor plate for an NB head but Ive done it and it works really really well.
Auto + sell a nice billet plate around 350 by memory fits perfect.
I've done it too, Dann. Really happy with it, especially the big torque spread.
Alex, you really need to come and drive my car again with this setup.
- Alex 2550
manga_blue wrote:I've done it too, Dann. Really happy with it, especially the big torque spread.
ok Phil, you twisted my arm
Retro NA8
When I moved from the stock NA8 intake manifold to the modified B18 Skunk2 I picked up massive amounts of power high up in the revs. The engine lost power pretty much everywhere south of 4500 but above that it pretty much gained an average of 20hp. I think the best gain was around 38hp at 7000rpm, 50hp with E85 but that was in a harmonic bump... All I changed on the car was the intake, throttle body, injectors and E85. I did port match the head to the manifold better than the stock NA8 intake so a bit would have been gained from that.
What this tells me is that a fully developed BP head flows more than the NA8 intake can supply... I doubt the manifold will help at all with a stock head where the flow is restricted at the valves or exhaust. If everywhere else is openned up so that the manifold is the restriction then these Skunk2 manifolds should help high end power considerably at the cost of lower and midrange power.
On a turbo build I assume you need to do less to the head to get them to work... how much though?
- NitroDann
Seems like reasonable logic to me. Good data too.
Re: RE: Re: Skunk Ultra Street Mazda NA/NB Intake Manifold
I have a cleaned up, flow matched and rebuilt head but with stock sized valves. I also have the same manifold as you. Will be on 9.5:1 and e85. I also have 272 cam and sub, springs etc to add later. Only once it's dynoed we will know how this manifold works (or doesnt) with a stock head. (However the manifolds we have are way different to the bp05/bp4w offering being discussed)madjak wrote:When I moved from the stock NA8 intake manifold to the modified B18 Skunk2 I picked up massive amounts of power high up in the revs. The engine lost power pretty much everywhere south of 4500 but above that it pretty much gained an average of 20hp. I think the best gain was around 38hp at 7000rpm, 50hp with E85 but that was in a harmonic bump... All I changed on the car was the intake, throttle body, injectors and E85. I did port match the head to the manifold better than the stock NA8 intake so a bit would have been gained from that.
Sent from my SM-G900I using Tapatalk
Hey cookie. Did you get the std head with this manifold dynoed? I'm curious about results
cookie wrote:I have a cleaned up, flow matched and rebuilt head but with stock sized valves. I also have the same manifold as you. Will be on 9.5:1 and e85. I also have 272 cam and sub, springs etc to add later. Only once it's dynoed we will know how this manifold works (or doesnt) with a stock head. (However the manifolds we have are way different to the bp05/bp4w offering being discussed)madjak wrote:When I moved from the stock NA8 intake manifold to the modified B18 Skunk2 I picked up massive amounts of power high up in the revs. The engine lost power pretty much everywhere south of 4500 but above that it pretty much gained an average of 20hp. I think the best gain was around 38hp at 7000rpm, 50hp with E85 but that was in a harmonic bump... All I changed on the car was the intake, throttle body, injectors and E85. I did port match the head to the manifold better than the stock NA8 intake so a bit would have been gained from that.
na6 progress thread - http://mx5cartalk.com/forum/viewtopic.php?f=57&t=68039
