Shifter Rebuild Kit
zacMX5aus
Shifter Rebuild Kit
Postby zacMX5aus » Sat Sep 16, 2017 12:27 am
Hi,
The time has come to fix the play in my gear shifter. I'm after some advice on where to purchase a complete kit with upper and lower boots and all bushings.
TIA,
Zac
Re: Shifter Rebuild Kit
Postby KevGoat » Sat Sep 16, 2017 1:01 am
I've always bought mine from here: MX5parts UK. Good service, good prices depending on exchange rates and fast freight.
davekmoore
Postby davekmoore » Sat Sep 16, 2017 2:34 am
Or ebay
zacMX5aus
Postby zacMX5aus » Sat Sep 16, 2017 11:58 am
I had looked at the mx5 parts UK kit, it's a good price and freight is cheap, but it doesn't seem to include all the nylon bushing some of the other kits come with. I was thinking of going with the rspeed kit but there's 50$ freight to aus :?
Postby Mr Morlock » Sat Sep 16, 2017 5:16 pm
The UK item is said to be genuine Mazda Parts - boots and a bush. You can check the price of these from Mazda Aust- adjust for freight. Others can comment whether this kit fixes "the play" in the existing set up. If a boot is torn you replace it- if it's not does it make any difference- perhaps the rubber has lost some elasticity? One thing that should be expected is that a genuine Mazda part is made to a spec. An aftermarket supplier r could make anything- good bad or indifferent.
wasp47
Postby wasp47 » Sun Sep 17, 2017 9:19 am
KevGoat wrote:I've always bought mine from here: MX5parts UK. Good service, good prices depending on exchange rates and fast freight.
And you don't pay UK VAT, gst which is In effect a 20% discount :D
zacMX5aus
Postby zacMX5aus » Sun Sep 17, 2017 1:13 pm
I've had the centre console out and can confirm the boots are perished/non existent..
It does seem like the kit from mx5 parts UK is the best deal going around, however still unsure where to source the other bushings from that do not come with that kit, any advice on that front?
davekmoore
Postby davekmoore » Sun Sep 17, 2017 9:02 pm
Maybe give MX5parts the VIN and ask them to supply everything?
two40
Postby two40 » Mon Sep 18, 2017 7:56 pm
Zac, I bought one on eBay a few weeks back which included everything you need and it was OEM. It came from Japan. Let me know if you're still looking and I'll dig up the link.
George
WTB
- Early NA Radio
- Crash pad for '89 NA
headlightsgoup.com
zacMX5aus
Postby zacMX5aus » Mon Sep 18, 2017 9:11 pm
two40, that'd be great, thanks :)
have you installed it yet? if so did you feel much difference post-install?
two40
Postby two40 » Wed Sep 20, 2017 10:46 pm
This is the kit I used. They had 212 units but unfortunately currently sold out. Maybe email them to ask if they're getting more in soon... otherwise search around and I'm sure you'll find it elsewhere. Just make sure it's the full 8 piece kit.
http://www.ebay.com.au/itm/MAZDA-MIATA- ... 1492965446
My shifter had never been rebuilt so it was in a sorry state with no oil in the turret at all (evaporated) and a broken washer inside the turret. A couple of photos here: http://headlightsgoup.com/2017/08/shifter-rebuild/
So yes, I did feel a difference in my case. The shifter was visibly tighter and engaged with a much more satisfying action.
Often you'll find the boot is all torn so apart from shifting feel this kit will improve sound and smell insulation.
George
WTB
- Early NA Radio
headlightsgoup.com
davekmoore
Postby davekmoore » Wed Sep 20, 2017 11:40 pm
Instructions might not mention using Loctite on the three top bolts. Strongly recommended as any loosening of those three bolts will give you a floppy shifter again.
two40
Postby two40 » Thu Sep 21, 2017 9:30 am
You got instructions? Is there such a thing for working on cars? :shock: :P
George
WTB
- Early NA Radio
headlightsgoup.com
Postby Mr Morlock » Thu Sep 21, 2017 8:35 pm
yes there is such a thing as instructions- its commonly known as a workshop manual and sometimes its enclosed in an old style piece of technology called a book. Rubber breaks down simply on the basis of old age. The NB Mazda workshop manual is actually a really good resource- written by engineers for mechanics - not sure if the same goes for NA.
myredmx5
Postby myredmx5 » Sun Sep 24, 2017 9:28 am
PM sent
