Could some wise person shead some light for me. Mine is a 98 NB8A with a highly modified normally aspirated engine (new).
Just run in and gave it a good run at Winton. I normally run it to 8000rpm with no issues, but because it's fairly new (1500 kms) limited it to 7500 rpm. Occassionly l was getting a slight miss at about 6500rpm with the tachometer needle bouncing. New plugs, comp ht leads, throttle body sonic cleaned, cam angle sensor and crank angle sensor standard, as is fuel pump.
Coiack failure
- Vehicle: NA8 - Supercharged
Re: Coiack failure
What ECU is in it? Is it rev limiting by cutting spark?
Re: Coilpack failure
Using a Microtech LT10s
Re: Coiack failure
I was thinking that if the ECU was cutting spark then the tacho would bounce around if the tacho is still dríven off the coilpack. If the tacho is dríven off the ECU then that's another matter.
- bruce
- Vehicle: NA8 - Turbo
Re: Coiack failure
When I had problems with my coiack, my doctor said I should eat more fibre.
- NitroDann
Re: Coiack failure
Consider the ignition trigger.
Re: Coiack failure
I had exactly the same symptoms. Rapidly deteriorated (the next run on the track that day it was much worse). I had blown one of my Toyota COP coils. New coil, all fixed.
Re: Coiack failure
bruce wrote:When I had problems with my coiack, my doctor said I should eat more fibre.
Hahahahahha
- bartmanftw
Re: Coiack failure
As Dann said look at the cam/crank trigger sensors. The tacho is ECU dríven, not coil dríven so if you are getting a misfire and the tacho is dropping out then it is most likely one of your trigger sensors is dropping out.
Re: Coiack failure
Thanks for the constructive responses as well as the smart arse ones.
Not a great typist with one finger on an iPad. Sorry guys.
I'll check trigger sensors first before going onto coilpack
