Stock 1.6 NA, no power, (less than normal :-)
Posted: Sat Jul 22, 2017 9:39 am
Hi all, My 1989 Eunos has lost a lot of power over a couple of weeks. So much that it's very difficult to get it off the line on an incline.
It started by being sluggish when cold, but would then come good as it warmed up. I put it down to old plugs and changed them when I got a the chance. No change, so replaced the leads, still no change, so replaced the coil pack as there was some evidence of tracking. Still no good.
It's gotten worse and is hardly driveable. Symptoms are loss of power as soon as you begins to release the clutch, almost as though the timing isn't advancing. I've checked, and reset it to the stock 10deg. When you do manage to get the clutch out there is no throttle response, with the engine just chugging over. With some coaxing up to 2500 - 3000 it then seems almost normal, revving out to about 5500. I've checked the a.f.m. and it's free to move. Next steps are to check the a.f.m temp sensor and do a compression test. Any other thoughts or advice that might be causing the issue?
Many thanks in advance.
