NA/NB side shaft query
Posted: Fri Jul 07, 2017 2:48 pm
Question:
Are the NA8 (non ABS) and NB8A (non ABS) side shafts the exact same. I believe they are compatible but the part catalogues show they are different part numbers (unsure of why). I believe the NB had a different sub-frame (wider track) as such, I'm not sure if the actual shaft itself is longer. Because there have been so many cars which have been modified (upgrade diff, widen track, swap sub-frame etc) it's hard to get a definitive answer.
I want to try and eliminate any chance for misinformation. What I do know is as per below.
Catalogues show
NA8 shaft # MD0225500 (non ABS) / MD0325500 (ABS)
NA8 shaft # MD2125500R0A (remanufactured part #)
NB shaft # MD1225500A / BC4C33471 (ABS sensor, possible tone ring???)
NB shaft # MD2125500R0A (remanufactured part #)
So, anyone with a bone stock NA8 side shaft able to measure or do a comparison against an NB side shaft?
Catalogues show
