Hard starting NB8B
1600Dave
Hard starting NB8B
Postby 1600Dave » Sat Jul 01, 2017 12:30 am
OK, slightly strange issue. Car has been harder to start over the last few months - takes 4-5 seconds of cranking before it will fire. Does this whether its hot or cold. Always starts, just takes a while. If you turn the car off and straight back on, it fires up OK. Leave it sit for a while, takes longer to fire.
However, if I turn the key to "On", wait for 5 seconds, then crank it over, it will start within 1-2 seconds every time.
I've replaced the fuel pump, I thought perhaps it was getting a bit lazy, but that didn't make a difference.
Any suggestions would be appreciated, its more an annoying problem than anything major.
jordan.k
Re: Hard starting NB8B
Postby jordan.k » Sat Jul 01, 2017 2:38 am
If you're saying its fine after you let it prime i'd put my money on the fuel filter being a bit clogged. Probably due for a change anyway.
Have had similar issues on other cars and changing the fuel filter improved starting time noticeably. GL
NA6 Dulux spec
1600Dave
Postby 1600Dave » Sat Jul 01, 2017 11:02 am
Ta, I'll grab one and see how it goes.
Postby 93_Clubman » Sat Jul 01, 2017 11:36 am
+1 for fuel filter as first thing to replace.
Todd77
Postby Todd77 » Tue Jul 04, 2017 11:27 pm
jordan.k wrote:If you're saying its fine after you let it prime i'd put my money on the fuel filter being a bit clogged. Probably due for a change anyway.
Spot on!!!!!
Postby bruce » Wed Jul 05, 2017 4:19 pm
Sounds like a battery too.
This cold weather does mean difficult starting.
beavis
Postby beavis » Thu Jul 06, 2017 2:08 pm
bruce wrote:Sounds like a battery too.
While that is very true, it probably wouldn't explain his symptom of "if I turn the key to "On", wait for 5 seconds, then crank it over, it will start within 1-2 seconds every time."
RS2000
Postby RS2000 » Thu Jul 06, 2017 3:06 pm
1600Dave wrote:OK, slightly strange issue. Car has been harder to start over the last few months - takes 4-5 seconds of cranking before it will fire. Does this whether its hot or cold. Always starts, just takes a while. If you turn the car off and straight back on, it fires up OK. Leave it sit for a while, takes longer to fire.
My track NB has been exactly the same for the almost 4 years I've had it. A new fuel filter didn't make any difference. I've tried jumper leads as battery ground & engine ground, but still the same. The strange part is the instant firing on the second start. It performs fine, so I've ignored it.
Postby 93_Clubman » Thu Jul 06, 2017 4:40 pm
Yeah, a few forumites have experienced this issue without resolution. Just had a look at Mazda TSBs & found following (Engine hard to start/ excessive cranking time) for NB8A: https://www.miata.net/garage/tsb/sb003_99.html
From memory I think some have also found replacing or checking & cleaning up the Main relay aka EGI relay in the engine bay fuse box has also helped.
1600Dave
Postby 1600Dave » Thu Jul 06, 2017 7:53 pm
RS2000 wrote:It performs fine, so I've ignored it.
Likewise. No dramas otherwise, its now becoming my routine to get in the car, turn key to "On", get settled, put seatbelt on, etc, then start it. Starts fine that way, but jump in and try to start it straightaway and it always takes a fair bit of cranking.
