AR-1 long term review
Posted: Sun Apr 30, 2017 10:06 am
Started them cold 26 and they went FL 32.4 FR 31.6 RL 33.7 RR 31.1
Lap times were 1:04.4440, 1:03.6285, 1:02.7184, 1:01.9994 (excludes in out lap). My previous PB was 1:00.47 so almost flat out on the last lap. They did feel a little 'squirmy' on the last lap, however this was more than likely due to incorrect pressures. Session 2 times with the AD08R's were 1:03.1237 1:02.7764 1:02.7777 1:02.3219.
Based on the temps (C), will set the fronts at 28 and the rears at 29 targeting 33/34 hot. Camber is approx -3.9°F and -3.5°R again very similar to what I run the AD08R's (33.5 psi hot). Not what I expected for a R Spec.
FL 47.2 52.2 60.5 (53.9 more pressure required)
FR 62.8 51.7 40.0 (51.4 almost spot on)
RL 57.2 57.2 59.4 (58.3 more pressure required, however temps seem strange)
RR 61.7 51.7 44.4 (53.1 more pressure required)
The quick glance at the surface tyre temps whilst on the track showed them getting to about 79°c when loaded up, but cooling down to about 60 on the straights. I do not log this data...
The AR-1's were taken off and then the AD08R's put on, so looking at the G Plots for session 1 and 2 should be a 'reasonable' comparison as conditions were similar. Note I did manage to do 1:00.4391 on the AD08R's much later in the day...
The AD08R's are showing better in braking, however was also taking it easy on the AR-1's so as to not flat spot them on the first outing. The blue circle (1.2g) shows that on the AD08R's the driver is making better use of turning/braking, but the AR-1's even on a heat cycle have just as much 'grip' as the well used AD08R's.
AR-1 by Eipeip, on Flickr
Will follow up with more data after the MX5 track day on 15/05/17.
