Issue today
roshmx5
Issue today
Postby roshmx5 » Sun Mar 19, 2017 7:33 pm
Hi Members today I was having a spirited run in my SP up a mountain and towards the top I noticed my tacho went from 4K up to about 6k and I wasn't on the accelerator. Is this normal or is my clutch on the way out.
Mazda MX5 SP
StillIC
Re: Issue today
Postby StillIC » Sun Mar 19, 2017 7:58 pm
Were you changing down a gear at the time?
roshmx5
Re: Issue today
Postby roshmx5 » Sun Mar 19, 2017 7:59 pm
No I wasn't was in same gear.
Mazda MX5 SP
StanTheMan
Re: Issue today
Postby StanTheMan » Sun Mar 19, 2017 8:05 pm
Check your wiring under the dash if you have an alarm installed. Chances are, it's been butchered & the wiring is affecting it. Wires touching where they are not supposed to be. ask me how I know. :roll:
roshmx5
Re: Issue today
Postby roshmx5 » Sun Mar 19, 2017 9:36 pm
Ok I will check under dash. I will ask you how you know
Mazda MX5 SP
JBT
Re: Issue today
Postby JBT » Mon Mar 20, 2017 3:17 pm
roshmx5 wrote:...towards the top I noticed my tacho went from 4K up to about 6k and I wasn't on the accelerator. Is this normal or is my clutch on the way out.
Did the engine note change as well or was this an instrument indication only? If the noise increased as well as the tacho indication, then you probably have a slipping clutch.
roshmx5
Re: Issue today
Postby roshmx5 » Mon Mar 20, 2017 3:25 pm
Thanks JBT I think the noise didn't change from memory
Mazda MX5 SP
roshmx5
Re: Issue today
Postby roshmx5 » Wed Mar 22, 2017 2:07 pm
All good guys, no issue with clutch.
Mazda MX5 SP
