ND Transmission - big clunk in reverse
Gypsy-Danger
Postby Gypsy-Danger » Sun Feb 05, 2017 7:11 pm
Hi guys,
Just seeing if anyone else has experienced this issue when during a cold start, putting the car in reverse and hearing a big clunk?
It almost feels like the car feels stuck when you first start to reverse, but then runs completely fine after the big clunk. Anyone know what the sound might be?
But I have found that if I drive forwards first before putting it in reverse I don't get that problem.
Shadgrind
Re: ND Transmission - big clunk in reverse
Postby Shadgrind » Sun Feb 05, 2017 7:39 pm
Many cars seem to benefit from being put into a forward gear before reversing. I always select any forward gear, you don't have to move. Then select R.
Postby bruce » Sun Feb 05, 2017 8:09 pm
Check the fluid level?
davekmoore
Postby davekmoore » Sun Feb 05, 2017 10:42 pm
Shadgrind wrote:Many cars seem to benefit from being put into a forward gear before reversing. Sent from my iPhone using Tapatalk
or neutral and clutch up then down again before selecting reverse.
Postby Mr Morlock » Mon Feb 06, 2017 5:34 am
New car that is not right. Back to dealer for check and rectification.
smy0003
Postby smy0003 » Mon Feb 06, 2017 8:14 am
Welcome Gypsy-Danger,
I think everyone has assumed you have a manual, but I get this sometimes in Autos that I drive. Do you have the auto?
Morlock is right, if you think it is abnormal go and see your dealer.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Gypsy-Danger
Postby Gypsy-Danger » Mon Feb 06, 2017 11:20 am
smy0003 wrote:Welcome Gypsy-Danger,
I have a manual and have had the car for about 4 months now.
Might go get it checked with the dealer just in case
JBT
Postby JBT » Mon Feb 06, 2017 5:08 pm
Rear brake discs rusted overnight from damp conditions?
pcmx5
Postby pcmx5 » Mon Feb 06, 2017 7:28 pm
I think there has been an issue with the rear discs clunking that has been mentioned on Miatanet,maybe that is it?I have no drama with mine.
Peter.
Postby manga_blue » Mon Feb 06, 2017 7:37 pm
Many cars do that. It's usually the surface rust on the rotors which causes the pads to stick to them a bit. When you set of in reverese the pads move with the rotors for a millimeter or so until they reach the end of their free play and then let go of the rotor with a clunk.
OMY005
Postby OMY005 » Mon Feb 06, 2017 7:46 pm
The same happens to me (ND) after washing the car, putting it away and not driving for a week or so. Rust on disc's like mentioned above.
Andrew
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Gypsy-Danger
Postby Gypsy-Danger » Mon Feb 06, 2017 9:56 pm
Okay cool, I feel a little more relieved knowing that other people have experienced something like this too.
Rust on the rear could be the cause, might keep an eye on the conditions in the morning as I do keep it under a carport.
Thanks for the help guys :D
pcmx5
Postby pcmx5 » Mon Feb 06, 2017 10:24 pm
There is an issue with rear brakes rattling as well that is covered by a Mazda Service Information.REF No.E118/15A and they replace the rear brake caliper support and the rear pads(Worldwide).May be completely unrelated to your issue but worth knowing.
Peter.
Postby Mr Morlock » Tue Feb 07, 2017 5:03 am
It still needs a diagnosis. I would not have thought this should be happening on a new car.
