AN-6 to hardline adaptor Q
3gress
Postby 3gress » Thu Jan 19, 2017 1:18 pm
Hey guys, i had planned to use aeroflow AN-6 to 5/16" hardline adaptors (part no.# AF108-05BLK) mounted directly to fuel pump cover lines. I cut the end barbs off and was left with only 11/16" of pipe where 3/4" is suggested as minimum (at least for an Earls fitting).
Has anyone used (aeroflow) hardline adaptors on the hardlines coming out of fuel pump cover?Image
StanTheMan
Re: AN-6 to hardline adaptor Q
Postby StanTheMan » Thu Jan 19, 2017 2:52 pm
is this for an E85 sensor?
3gress
Postby 3gress » Thu Jan 19, 2017 4:58 pm
It is for AN braided line installation. Reduces the amount of joins between hardline, fuel hose and the braided line. Cookies worklog shows pics of a setup i believe he sourced from flyin miata that includes barb to AN fittings, was hoping to go from hardline straight to AN.
zossy1
Postby zossy1 » Sat Jan 21, 2017 8:47 am
Unless you're using PTFE core hose, I'd just use a hose clamp finisher.
3gress
Postby 3gress » Sat Jan 21, 2017 10:48 pm
Thanks zossy1, lucky this is a spare pump cover as I'd already cut the end barbs off. I fit one of the hardline adaptors and it seems to have fit well, just don't particularly want them to fail and spray fuel all over the place.
I have used thes type of brass olive fittings on a previous build with no issues though I'd feel safer with the flared end type fittings, just cannot justify the cost of a flaring tool for one off use.
I have some hose finisher clamps somewhere in the shed, maybe fit a second extinguisher too just in case. :D
