So it went fine all the way to Gundagai where we stopped to top up the fuel and get him some more cold water. After fueling it up it wont start. Cranks and cranks but doesn't start.
While we waited a while for it to cool down a bit (which didn't help), we did a little googling about cam position sensors and what not, but after waiting an hour for things to cool there is no change. Eventually ended up heading back to Canberra and getting a car trailer and bringing it home that way. Safe and sound now at home!
So, some symptoms and observations based on all my googling, but not too familiar yet with different models so all the threads I read I get a little confused about it applying to directly to this car.
It's a '95 NA8
Cranks no problem, but won't fire at all
Give it a little gas and the engine just shakes pretty bad, no throttle and it just cranks pretty smoothly
With the key turned to 'on' I get the charge light and brake light only (the top two in the little window), not sure I should get the check engine light at that point
No RPM on the tacho at all during cranking!!
I expect the battery will be dead soon, so I'll put it on a charger.
I didn't have any tools with me at the time!
So, I'm thinking the heat has done something bad. Was nice to see the actual engine temp was kept in check the whole time by the cooling system though.
Anyway, apologies for the long post, but I certainly appreciate any help and insight anyone can offer as I learn about the car (i'll take this as a great opportunity to learn stuff about the car I might not have before).
