Throttle pedal bushes (NA)
Hoolio
Postby Hoolio » Thu Nov 10, 2016 11:40 pm
My throttle pedal bushes are badly worn. Mazda tells me that they are no longer available. Is there another source? If not, is there another simple solution? Otherwise I will engineer something exotic as a relacement…
StanTheMan
Re: Throttle pedal bushes (NA)
Postby StanTheMan » Fri Nov 11, 2016 5:37 am
3 d printing.......
Postby 93_Clubman » Fri Nov 11, 2016 3:34 pm
Rolley
Postby Rolley » Fri Nov 11, 2016 5:24 pm
Part# 025941644 they are under $2ea plus post.
I'll be throwing a couple into my next order after melting a set I forgot to remove when welding up a cracked spare pedal box.
Big Amayama fan here.
Hoolio
Postby Hoolio » Sat Nov 19, 2016 12:56 pm
Thanks 93_Clubman wrote and Rolley, that's just the kind of answer I was looking for 8)
