Car won't turn over - Suspected fuel pump
Staaahp
Postby Staaahp » Thu Nov 10, 2016 10:51 am
Went to fill up petrol yesterday and after filling up the tank the car would start up and idle for 2 seconds eventually dying.
2 cranks later the car refuses to start now. I've tried changing spark plugs and leads so far with no luck.
Anyone have any issues with the walbro 255 fuel pump just giving up out of the blue? Either that or I feel like it could be bad fuel.
Cars turbo running a chiptorque. May be an issue with the map perhaps.
Note: Car's never sees anything other than 98. First time using Speedway as I was in a rush. :cry:
slyfox2151
Re: Car won't turn over - Suspected fuel pump
Postby slyfox2151 » Thu Nov 10, 2016 11:24 am
Does it run if you use startyabastard? Easy and cheap way to test it...
Staaahp
Postby Staaahp » Thu Nov 10, 2016 11:49 am
I'll drop by and pick up some on the way home.
Although, now that I think of it I can usually hear the fuel pump engage when turning on the electricals. I'm quite positive that sound is now non-existent. I'll double check when I get home nevertheless.
StanTheMan
Postby StanTheMan » Thu Nov 10, 2016 11:57 am
NA, NB NC?
do you have fuel & Spark
on the NA's NB's at least, you can isolate the fuel pump through the diagnostics box. You can bypass the relay. If the fuel pump is not working It may also be your relay.
If you have fuel & spark......that's another story
Staaahp
Postby Staaahp » Thu Nov 10, 2016 4:16 pm
Ok so I just got home. Decided to try my luck and try one more time to start it before I fiddled around with stuff.
It seems to now magically run like normal. Cars running smooth with spark and fuel. Got fuel tested and it's fine. I honestly have no idea what's up at this point. Any chance of it being a blocked fuel filter or something?
NB btw
StanTheMan
Postby StanTheMan » Thu Nov 10, 2016 4:31 pm
could be your Relay or Fuel pump playing up. If you are certain you didn't hear it prime last time.
Ive had had a wiring issue as well as an intermittent fuel pump problem mine the past. Mine is an NA6
NB's are known for Relay issues
Postby hks_kansei » Thu Nov 10, 2016 4:42 pm
When fuel pumps go it's not always and all or nothing thing.
It can come and go, usually it will work first off but after a drive (heating up) the pump won't start the second time.
I'd be checking the relay as mentioned, relays are cheap, and over time they do get sticky and cause issues.
Then look at the pump.
Staaahp
Postby Staaahp » Thu Nov 10, 2016 9:13 pm
Thanks guys, i'll have a proper look at the relay and get it sorted out.
Really appreciate the responses.
speed
Postby speed » Fri Nov 11, 2016 7:52 am
Hope you get it sorted mate. Looking forward to meeting you and your car soon :)
StanTheMan
Postby StanTheMan » Fri Nov 11, 2016 8:10 am
To my knowledge and please correct me if I'm wrong, is that the relay generally doesn't go intermittent. Ive read some members keep a spare one in their glove box.
Postby hks_kansei » Fri Nov 11, 2016 9:43 am
Not sure about the mx5 fuel relay specifically, but I've had relays go intermittently a few times.
They're essentially just a light switch that completes the contacts (not too different to points in a dizzy)
But because the switch is triggered by a small electromagnet, if the contacts get corroded or whatever, it can stick open or closed and the magnet can't pull hard enough to fix it.
Postby 93_Clubman » Fri Nov 11, 2016 3:40 pm
If NB8A (ie 1998 to Sep 2000) then you might also consider one of the coils in the coilpack.
Staaahp
Postby Staaahp » Sat Nov 12, 2016 1:54 pm
The car is a NB8A. I've had a chance to drive it around a bit to see if the problem still persisted, meticulously ensuring the the fuel pump was priming as intended. No issues so far.
Also had a closer look at the relay this morning but couldn't notice anything out of the ordinary. That being said, i'm definitely replacing it on Monday to not risk getting stranded again.
I have a set of LS3 coils going in very very shortly so that will hopefully eliminate the possibility of a malfunctioning coilpack! :D :NB8B:
