where is oxygen sensor plug
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Oct 16, 2016 5:58 pm
hey guys, just wondering if anyone has a pic of where the oxygen sensor plugs into. by that i mean the end that doesnt plug into the exhaust its self.
can't find it for some reason.
found my oxygen sensor is unplugged.
RS2000
Re: where is oxygen sensor plug
Postby RS2000 » Sun Oct 16, 2016 9:10 pm
On NB8A it goes to connector at the front centre of rocker cover.
Postby NitroDann » Sun Oct 16, 2016 9:36 pm
Top of rocker cover area on all Na/nb
16bit
Postby 16bit » Sun Oct 16, 2016 10:10 pm
which end, the fire wall or radiator end?
i can't find it for the life of me. its a black connector and cant find anything within reach of the cord that fits it. truly bizarre.
say the connector is no longer there where would it trace back to? makes me wonder if its just not there at all.
Postby NitroDann » Sun Oct 16, 2016 10:12 pm
Back of the head near the lift point on most models.
speed
Postby speed » Mon Oct 17, 2016 8:12 am
For which model? Your profile says ND 2.
Postby manga_blue » Mon Oct 17, 2016 8:28 am
Rear of the cam cover on the passenger side on an NA8, just above the CAS. The lead to it comes from the loom which goes around the back of the inlet manifold and under the coilpacks. The O2 sensor plug on the loom is attached to a tab on a CAS saddle bolt. If it came off that tab then I guess it would fall to the top of the clutch housing.
Postby hks_kansei » Mon Oct 17, 2016 8:49 pm
Nb8a will be clipped to a small bracket at the front of the rocker cover, the bracket attaches to one of the bolts near the exhaust cam pulley
Black 4 pin plug, 4 wires to it with a Black high temp sleeve over them.
One wire is blue (o2 signal)
And from memory the others are red, black and grey (might have them confused with the wires on my Bosch sensor)
16bit
Postby 16bit » Tue Oct 18, 2016 4:33 pm
thanks guys.
will have a look on the weekend and see if i can find the Flower!
16bit
Postby 16bit » Sat Oct 22, 2016 2:53 pm
found it thanks yall
