NA8 Only Firing on 3 Cylinders
myredmx5
Postby myredmx5 » Fri Oct 07, 2016 6:26 pm
I have had this problem for a few weeks and finally nailed it.
Google was of no help what so ever.
Things I tried.
First which cylinder was not working. Started engine, took each lead off the spark plug, number 1, 2 and 3 all caused the engine to falter more, then number 4 had no effect on engine. Changed the plugs, coil, leads no difference. Shorted the plugs on the rocker cover, all fired fine but I did notice number 4 plug was covered in unburned fuel. Did a compression test which was fine. Finally changed the injector and all was fine.
Re: NA8 Only Firing on 3 Cylinders
Postby manga_blue » Sat Oct 08, 2016 10:07 am
Textbook diagnosis. Mind you, if the injector check didn't work you would have got to looking for a dead mouse in the inlet tube. :D
myredmx5
Postby myredmx5 » Sat Oct 08, 2016 1:21 pm
manga_blue wrote:Textbook diagnosis. Mind you, if the injector check didn't work you would have got to looking for a dead mouse in the inlet tube. :D
No mouse just clogged or dead injector.
When replaced all worked fine.
