Engine ID help
GR124
Vehicle: MX5 Locost
Engine ID help
Postby GR124 » Wed Sep 14, 2016 3:19 pm
Hi guys
I've bought an engine from 2000 MX5. Im told it is a 1.8
can some of you knowledgeable people answer the following
* Is it a 1.8?
* does it have VVT?
* power output?
* Would this be a good track engine, eg free reving?
smy0003
Re: Engine ID help
Postby smy0003 » Wed Sep 14, 2016 3:21 pm
Yes, no, and it'd be a servjcible track engine if it's healthy.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
GR124
Vehicle: MX5 Locost
Re: Engine ID help
Postby GR124 » Wed Sep 14, 2016 3:30 pm
just under 100KM on it.
I know the Ks are not ideal :| for track.
I'm building a budget clubman track car
Re: Engine ID help
Postby manga_blue » Wed Sep 14, 2016 3:37 pm
It's a BP4W 1.8l engine from a 1998-2000 NB8A. It's not as powerful out of the box as a later VVT NB8B engine but it is very easy to modify as a track engine. It's a popular choice for track cars.
smy0003
Re: Engine ID help
Postby smy0003 » Wed Sep 14, 2016 3:37 pm
Just under 100k kms is pretty good going for a 16 year old engioldne. Plenty of laps left in it.
Do you mean an mx5 na8 clubman or a lotus 7 type clubman.
GR124
Vehicle: MX5 Locost
Re: Engine ID help
Postby GR124 » Wed Sep 14, 2016 3:40 pm
lotus 7 type clubman :D
StanTheMan
Re: Engine ID help
Postby StanTheMan » Wed Sep 14, 2016 3:46 pm
GR124 wrote:Hi guys
* Is it a 1.8? Yes
* does it have VVT? No
* power output? 104 Killer wasps at crank
Free revving? anything can be made that way. but as standard? Prolly not as free revving as an NA6 engine. but if you are considering tracking it.....may as well make it free revving. But significantly more powerful than the 1.6 block.
GR124
Vehicle: MX5 Locost
Re: Engine ID help
Postby GR124 » Wed Sep 14, 2016 4:07 pm
Thank you StanTheMan and others for their response, it sounds like this engine will be a good fit for my purpose.
Re: Engine ID help
Postby hks_kansei » Wed Sep 14, 2016 4:24 pm
All the above.
I'd be doing he head gasket while it's out, since its easy, and who knows how long the previous owner had he engine running with the rad split.
GR124
Vehicle: MX5 Locost
Re: Engine ID help
Postby GR124 » Wed Sep 14, 2016 4:30 pm
hks_kansei wrote:All the above.
good pick up, I'll look into that, Thanks
StanTheMan
Re: Engine ID help
Postby StanTheMan » Wed Sep 14, 2016 5:06 pm
looks like its had frontal impact?
Re: Engine ID help
Postby hks_kansei » Wed Sep 14, 2016 5:38 pm
Also check for bent pulleys etc on he front, not hard to replace, but annoying to track down just the pulleys without having to buy the alternator etc they're attached to.
Basically have a look and see if the impact caused anything to be pushed into the front of the engine e.
