Clutch Cylinder Replacements
Posted: Sun Sep 04, 2016 2:40 am
Hey folks,
had my clutch go today. bummer... Anyway to cut it short, either my master or slave has gone but i'm having trouble identifying which to replace. so at this stage I'm leaning towards just doing them both. If i can figure out the culprit though, id appreciate only buying one part. Also, can anyone recommend a dealer/shop for parts in the south eastern Sydney area? can't exactly drive anymore so the closer the better
So i've read just about as many forums and watched as many videos on the topic as humanly possible this afternoon but im still stumped.. The pedal understandably has no feedback now. very loose feeling. The fluid looks as black as anything ( which i understand is normal?). I don't appear to be loosing any fluid, can't find any leaks. Also had a feel of the rubber boot on the slave to check for fluid leaking with no evidence to suggest that this is the case. thoughts?
cheers.
cheers.
