Coolant reroute question
dzammit85
Postby dzammit85 » Mon Aug 29, 2016 10:37 pm
Hi,
i was searching up coolant reroutes and found this video https://www.youtube.com/watch?v=mRharubfD1E
i was just wondering if there is any difference between this and buying the m-tuned kit, it seems to me that whichever method i use it is still rerouting the coolant, the only difference i can really notice is that i can pick up all the parts from that youtube video for around $150, and the m-tuned kit is around $500 sent to aus. if i could get anyones opinion on why they think the m-tuned kit would be better (considering they have such a high rep) or why not to do it the youtube way, or if there is no difference between them, and I'm strictly talking about cooling the motor, I'm not fussed about how it looks, or additional outputs
Thanks
smy0003
Re: Coolant reroute question
Postby smy0003 » Mon Aug 29, 2016 11:06 pm
http://www.ebay.com.au/itm/Mazda-MX5-NA-NB-NA8-NB8A-NB8B-BP-1-8L-Coolant-Re-Route-Spacer-Kit-/272341825794?hash=item3f68d67902:g:tvkAAOSwInxXNUCu
Add hoses to taste.
EDIT: Remember that the NB8B has a different head gasket to compensate for the bad cooling. Most reroute kit manufacturers say that reverting to a pre-NB8b head gasket is recommended if using a reroute.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
bear2230
Postby bear2230 » Mon Aug 29, 2016 11:14 pm
NitroDann does a reroute kit and its a cracker. I have one on the white car and is easy to do yourself (relatively) and much better.
NitroDann wrote:Coolant Reroutes
Available for all na/nb models.
Includes TIG welded stainless hardpipe, MX5+ cnc machined spacer, new genuine thermostat cover, silicone tube and all new clamps and bolts, washers, everything.
Also all the parts you need to remove the front thermostat housing and give your engine a fantastic tidy look.
ALL MODELS $300+ ship.
dzammit85
Postby dzammit85 » Mon Aug 29, 2016 11:47 pm
ok thanks for replies, ill check with dan for the kit considering it comes with everything and is still at a reasonable price
as for the head gasket, i was reading up on miataturbo.net and it says its not a huge issue if i keep the standard 01 head gasket on there, heres the link http://www.miataturbo.net/race-prep-75/ ... ead-79930/ its a few comments down
thanls
rascal
Postby rascal » Mon Aug 29, 2016 11:56 pm
I did my coolant reroute on my NB8A for around $50.
Just swap the factory necks between front and back, (they're interchangeable) a length of alloy tube about $7 from action aluminum to run from back of head to radiator, two hoses to connect this tube to the rear neck and radiator $15 ea at supercheap/autobarn and 1m of heater hose to reach the heater barb on the neck now at the front.
There is a bung in the back of the head to put the temp sensor in to avoid needing to extend any wiring, and put that bung you remove into the neck now on the front to plug that hole.
Very easy, and been working perfectly for a few years and 20+ track days now..
dzammit85
Postby dzammit85 » Tue Aug 30, 2016 12:08 am
rascal wrote:I did my coolant reroute on my NB8A for around $50.
yeah thats exactly like the youtube video i watched, minus where you put the temp sensor, thats great, looks like ill be doing it on the weekend, thanks
Code4
Postby Code4 » Tue Aug 30, 2016 7:56 am
FYI
I haven't installed mine yet but got the idea from here:
http://revlimiter.net/blog/2011/05/coolant-re-route-1/
and bought parts with a combo from eBay and here:
http://www.bellengineering.net/index.ph ... 65_240_244
Never put the top up unless the storm has a name.
datfreak
Postby datfreak » Tue Aug 30, 2016 9:28 pm
see site:
https://squareup.com/store/hawleyperformance/
the price is ok - $115us plus post. Maybe cheaper if a few of us do a group buy(i'd be in if we can share shipping costs)
Guy who makes them is discussed here
http://www.miataturbo.net/miata-parts-sale-trade-5/coolant-block-off-reroute-spacer-egr-block-off-egr-block-off-fpr-mount-88962/
Users browsing this forum: Google [Bot] and 2 guests
