air con removal
Posted: Mon Aug 22, 2016 1:00 pm
by 16bit
anyone removed aircon from an nb8a?
i have tried looking for a step by step but can only find it for an NA.
if anyone has a link to instructions that would be ace!
my compressor has a leak and I can't be bother to get it replaced so thought i would just remove it.
there shouldn't be any gas in my system at all.
Re: air con removal
Posted: Tue Aug 23, 2016 12:15 am
by a222133
na/ nb all much the same , back off 2 turnes of 14mm [ head] bolt on the centre of the tensioner pulley , wind down 10mm [head ] anti clockwise of long bolt on tensioner bracket , the pulley should now be moving down towards the ground with each turn . Move pulley down about 25mm the belt should now come off . you may have to remove any belts in front of a/c belt to get a/c belt off . Undo the suction and discharge lines , if your unsure about whether the system still has a charge [pressurised ] in it , just back off the pad / hose fittings on the compressor a few turns give them a wriggle and see if any gas escapes , if yes it will now totally discharge over the next 20/30 minutes . totally remove hoses from compressor , undo bolts holding comp. onto bracket [ maybe 4 bolts ] . If the comp shows no sign of an oily substance [ a mixture of R134 and lub. oil ] on the surface then it may well be a good comp . Now either rip out the rest , condenser ,drier, tube work etc , or just seal up the hosses . Don't forget to tighten the first 14mm and also 10 mm bolt up if you intend to leave the tensioner bracket on the car this is
'important . If you want more info let me know .
Re: air con removal
Posted: Wed Aug 24, 2016 2:03 pm
by 16bit
thanks mate.
Re: air con removal
Posted: Mon Sep 05, 2016 4:13 pm
by 16bit
those looking for some instructions on this process these bits might help.
http://www.miata.net/garage/Miata%20NB% ... 0Guide.pdf - belt removal and replacement
this too
http://raysmiatabuild.blogspot.com.au/2 ... miata.html
Re: air con removal
Posted: Mon Sep 05, 2016 4:38 pm
by 16bit
Re: air con removal
Posted: Mon Sep 05, 2016 5:24 pm
by Odd
If you plan selling the AC unit....tape up ends of all pipes to make sure no moisture gets in the system
Re: air con removal
Posted: Mon Sep 05, 2016 6:17 pm
by 16bit
yeah cool.
the compressor is junk, might be able to be rebuilt but leaking like a sieve.
might be able to sell the other bits though.
thanks!
