so my daughters '90 1.6 has clocked over 400k and she commented that it's been running rough.
So I have a listen and almost cry. First thought, head gasket, but no oil in water or vice versa.
Compression is 175, 170, 110, 175. So likely a Valve.
Its the original motor with a SNC. Is it worth rebuilding?
We have at our disposal a '98 JDM 1.6 with a BNC, with around 150k on it, but unsure of its quality, it was already removed from the donor and was cheap
PO said it was fine, Timing belt was done 20K ago, and I've no reason not to trust him.
So the short term plan is to drop the replacement in, The car is her DD so can't be off the road for long.
What should I check on the replacement before dropping it in. It looks ok, as in no leaks or wet areas and hasn't been steam cleaned to hide anything.
