Nb8b coolant re route?
beavis
Re: Nb8b coolant re route?
Postby beavis » Tue Apr 12, 2016 11:27 am
no.
beavis
Postby beavis » Tue Apr 12, 2016 9:04 pm
The longer story is:
The stock cooling system is more than capable to manage a mostly standard car even when on the track in 35+degree heat.
That is provided the system is in good order. (Working thermostat, good fluids, radiator in good cond. etc.)
Even mild turbo setups work without a re-route (though i wouldn't do it myself).
Also, the effort to re-route an NB8B is higher than earlier MX's as it requires a change of head gasket.
If you were concerned on cooling your car, I'd just spend the $160 odd dollars on a aluminium radiator from ebay.
Postby Okibi » Tue Apr 12, 2016 10:18 pm
Another easy fix is moving the licence plate if it's mounted in a way that it blocks flow to the radiator.
Muzdaman
Postby Muzdaman » Tue Apr 12, 2016 11:56 pm
http://www.miataturbo.net/race-prep-75/ ... ead-79930/
Lots of good info re cooling here.
It also okays reroutes on nb8b, but its better again with a head gasket swap.
Users browsing this forum: Google [Bot] and 2 guests
