185kw turbo built na6 engine -what do I need?
Hi all,
So I've decide to go turbo and have the following.
Begi exhaust manifold.
T28 turbo.
Sump with oil return.
Water and oil lines.
Eagle H beam forged rods. (Came with forged pistons but 2 are scored)
Dump pipe.
Rx8 injectors.
Toyota COPS.
Nitrodann coolant reroute.
MS2.
Yet to source a tube and fin cooler and make my own alloy piping.
Apparently I'd need to run 16psi at 6,000rpm to get 185kw atw.
Will be paying to have the head and block machined and head assembled with new valve stem seals etc.
Crank will also be machined.
Questions below:
1.Before I do this, should I be going for an increase in piston size and what compression are people running?
The forged pistons are 8.5 but should I go higher or lower. Some people have said that even stock 9.5 pistons would be adequate but I'm not so sure and don't want to skimp on the bottom end.
2. What bearings should I use?
3. Do I need to remove a lug to run water cooling for the turbo?
4. Would regular rebuild gaskets suit or do I need something special?
5. Including injectors; how much would an e85 set up cost me (parts)?
I.thought I'd be able to achieve my goal on 98 but would be good to know.
What have I missed?
Thank you very much,
Steve
T28 turbo.
Dump pipe.
Rx8 injectors.
Toyota COPS.
MS2.
Questions below:
What have I missed?
Steve
Re: 185kw turbo built na6 engine -what do I need?
speed wrote:What have I missed?
Cost of repairing/upgrading gearbox, differential and associated components.
5. an off the shelf solution https://www.flyinmiata.com/fm-nb-big-flex-fuel-kit.html
- ManiacLachy
- Engaged
Clutch upgrade? Or are you already running something stronger than stock?
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
You could just install a V6. 185kw's and no turbo.
- NitroDann
speed wrote:Hi all,
T28 turbo.
Dump pipe.
Rx8 injectors.
Toyota COPS.
MS2.
Questions below:
Stock to 9 ish on 98, stock pistons and rings are fine if healthy.
OEM is fine.
Forget the water cooling. But if you absolutely feel the need check the miataturbo wiki
OEM
You can easily, if you want to.run united every day just fit a walbro 255 intank for 170 and id725 for 800
What have I missed?
Steve
Re: RE: Re: 185kw turbo built na6 engine -what do I need?
Okibi wrote:5. an off the shelf solution https://www.flyinmiata.com/fm-nb-big-flex-fuel-kit.html
Will check that out right now. Thankyou!
lightyear wrote:You could just install a V6. 185kw's and no turbo.
Really want an engineered turbo 4.
ManiacLachy wrote:Clutch upgrade? Or are you already running something stronger than stock?
Already have an upgraded clutch
1green5 wrote:speed wrote:What have I missed?
Already have a 4.1 torsen. The gearbox is a weak link but I'm a very simpathetic driver.
Is the engine stuff that I want to sort out before I arrange machining.
Bigger brakes, NA8/NB8A minimum.
Also +1 for the V6.
Also +1 for the V6.
chrons_rotary wrote:Bigger brakes, NA8/NB8A minimum.
Also +1 for the V6.
Got those too. Really want engine specs, namely pistons and water line bung.
- NitroDann
I posted answers to both.
Leave the pistons stock.
Dont run water. If you have to run water the info with pics is in the miata turbo wiki.
chrons_rotary wrote:http://miataturbo.wikidot.com/water-lines
Thanks Ken
NitroDann wrote:
Questions below:
Sorry Dann, I must have missed this post. Really appreciate your responses.
By 9ish, do you mean 9.0:1 and can I get away with a thick head gasket?
If so any idea how thick?
Also would stock pistons handle 16-20psi if tuned correctly?
Thanks again,
Steve
- NitroDann
Stock pistons will go deep into the 300whps
9:1 is fine, Id say just use your original ones and rering if necessary.
NitroDann wrote:Stock pistons will go deep into the 300whps
Ok great. Thank you very much.
