NC CEL Problem
garbev
NC CEL Problem
Postby garbev » Sun Mar 27, 2016 12:01 pm
Hi All
Anyone with an NC had this problem, I am running goodwin headers with standard midpipe and muffler, relocated the O2 sensor further down the midpipe per the mod instructions, while the car is running no CEL but once I turn it off and restart it CEL comes back on and I have to reset again, first start after the reset all is fine but let it cool down and restart and the light is back on, any suggestions?
__________
Zoom Zoom
If you can't go fast, go in style
MX5 Club of WA
Re: NC CEL Problem
Postby Regie » Sun Mar 27, 2016 7:31 pm
you'll need an OBD2 reader to find the code, we will be able to help then
Could be one of a thousand things
garbev
Re: NC CEL Problem
Postby garbev » Sun Mar 27, 2016 7:50 pm
Thanks Reggie
Thought that maybe it was a common problem, looks like I will have get a reader.
__________
Zoom Zoom
MX5 Club of WA
Re: NC CEL Problem
Postby Regie » Mon Mar 28, 2016 6:54 pm
if the O2 sensor extensions are touching the exhaust they will short. It may throw a code, but the car won't start as it will keep blowing the IGN fuse.
Depending on the year of the NC it could be a thermostat code its throwing.
shortSteve
Re: NC CEL Problem
Postby shortSteve » Wed Mar 30, 2016 10:08 pm
Did you relocate both O2 sensors, to either side of cat? Or can you get away with just relocating one and removing the other?
garbev
Re: NC CEL Problem
Postby garbev » Wed Mar 30, 2016 10:29 pm
Just relocate the lower sensor further down the midpipe past the secondary cat.
__________
Zoom Zoom
MX5 Club of WA
shortSteve
Re: NC CEL Problem
Postby shortSteve » Thu Mar 31, 2016 12:50 am
Ahh ok, I thought you had to relocate both, one pre and one post to measure the differences between the two. Glad I went with the midpipe with preinstalled O2 bungs! :)
