NA8 crank appearance
Posted: Fri Mar 11, 2016 5:00 pm
Just opened up a BP motor bought to rebuild. Not sure if the crank appearance is normal - all the counterweights have their outer edges machined, with some 8-10mm dia holes drilled a few mm deep (assume balancing drillings), and a couple of Very small drill marks - 2mm dia, less than 1mm deep. The cyl 1 counterweights have a couple of machined flats with numbers stamped in -2, K, 29.
Does this sound normal ?
Do the cams have any numbers cast or stamped on them normally?
thanks
jp 92 NA6, 96 NA8 with Turbo in a clubbie.
thanks
