NA8 crank appearance
jp928
Postby jp928 » Fri Mar 11, 2016 5:00 pm
Just opened up a BP motor bought to rebuild. Not sure if the crank appearance is normal - all the counterweights have their outer edges machined, with some 8-10mm dia holes drilled a few mm deep (assume balancing drillings), and a couple of Very small drill marks - 2mm dia, less than 1mm deep. The cyl 1 counterweights have a couple of machined flats with numbers stamped in -2, K, 29.
Does this sound normal ?
Do the cams have any numbers cast or stamped on them normally?
thanks
jp 92 NA6, 96 NA8 with Turbo in a clubbie.
Re: NA8 crank appearance
Postby manga_blue » Fri Mar 11, 2016 5:40 pm
OEM ones look like this.
jp928
Postby jp928 » Fri Mar 11, 2016 6:18 pm
Thanks, that looks the same. Excellent!
jp
Postby 93_Clubman » Sat Mar 12, 2016 11:40 am
jp928 wrote:Do the cams have any numbers cast or stamped on them normally?
From memory '5A' is cast onto them.
Postby manga_blue » Sat Mar 12, 2016 12:08 pm
Inlet cam on mine has BP and 05 cast on opposite sides of the shaft between 2 and 3. Exhaust has BP and 06.
Postby 93_Clubman » Sat Mar 12, 2016 2:31 pm
Must have been thinking of the NB8A:
http://www.solomiata.com/Mx5Engine.html
