Finding radiator leaks
Postby Magpie » Mon Feb 22, 2016 7:51 am
Noticed a very small coolant drip on the weekend when I was poking around under the car on Sunday. Not sure if I should take out the radiator or put some stop leak in it. It maybe lost 2ml overnight (Saturday) and a recent track days not much coolant was lost, actually I thought it was a little overflow.
Not really well focused but you can just see the green in the bottom right corner.
ImageDSCN3013 by Eipeip, on Flickr
Same region but using a UV Light
ImageDSCN3012 by Eipeip, on Flickr
And this is where the leak is possibly from, again using a UV light
ImageDSCN3008 by Eipeip, on Flickr
Shinning the torch over the rest of the radiator there were no signs of leaks.
Re: Finding radiator leaks
Postby hks_kansei » Mon Feb 22, 2016 9:01 am
Dont use stop leak.
While it will stop the radiator leaking for a while it will also gum up every single part of the cooling system with sh*t.
When my gf was rebuilding the engine in the Kingswood we discovered the previous owner used the stuff, every interior surface coated with a layer of the crap (can't be great for helpinmg the heat conduct into the coolant)
It had also collected at the bottom of the radiator essentially starting to block the drain plug, and bottom hose.
had to acid dip the block to get the crap out.
So yeah, try and avoid the stuff if you can.
Postby Magpie » Mon Feb 22, 2016 9:31 am
Thanks, looks like it will be a removal and repair job.
Postby Magpie » Wed Feb 24, 2016 7:12 am
Radiator removed and off to PWR this morning. PWR were great on the phone, advised they can test it the same day and advise if can be repaired. Found out the oil capacity of the cooler side of the radiator is about 700ml.
Looks like it is at one of the mounting points
ImageIMG_1291[1] by Eipeip, on Flickr
There was very little 'gunk' inside the radiator, however may take the opportunity to do a complete flush.
Using the UV light reminded me of this skit:
project.r.racing
Postby project.r.racing » Wed Feb 24, 2016 4:21 pm
Pressure test. 2 seconds of you life, and you'll locate the leak.
Steampunk
Postby Steampunk » Wed Feb 24, 2016 4:42 pm
Your radiator is leaking?
*how interesting... do go on...*
Postby Magpie » Wed Feb 24, 2016 4:44 pm
Ouch Steampunk, you have hurt my limited feelings...
More about using UV light to see the coolant and where it has been
https://youtu.be/CqkG3CqPbQk
Postby hks_kansei » Wed Feb 24, 2016 8:55 pm
I do the same to spot coolant leaks.
Even a blue led works, doesnt need to be Uv
Makes it 100x easier
Postby Magpie » Thu Feb 25, 2016 12:39 pm
Radiator repaired by PWR at no cost to me! Not bad service for something purchased almost 3 years ago. Top left hand mounting point was cracked.
project.r.racing
Postby project.r.racing » Thu Feb 25, 2016 5:17 pm
It was leaking cos a mounting point was cracked?
Postby Magpie » Thu Feb 25, 2016 6:49 pm
Yes, top passenger side where the OEM bracket attaches.
Postby Okibi » Fri Mar 04, 2016 1:03 am
Nice to hear PWR fixed it for free.
Users browsing this forum: No registered users and 39 guests
