faulty TPS
zorak
faulty TPS
Postby zorak » Sun Jan 17, 2016 4:23 pm
So a while back my nb8a started to develop a hesitation on acceleration. Coasting in gear and then getting on the throttle (not WOT) the car would hesitate for about 2 seconds before accelerating as normal.
Idle is completely normal and car has no power/hesitation problems running WOT.
I have replaced plugs, leads, 02 sensor, ecu is stock, fuel filter is only couple thousand kms old - no improvement
Today I disconnected the TPS and went for a drive. Car now idles at 1500rpm but hesitation has completely gone!
So does this make any sense and does it prove my TPS is the fault? I would have thought I would have a bad idle with TPS.
Could it be a bad connection or should I just replace it?
cheers!
NB8A
WP 1:10.69
SMSP (south) 1:04.41
SMSP (GP) 1:53.98
Re: faulty TPS
Postby 93_Clubman » Sun Jan 17, 2016 7:30 pm
Try very carefully cleaning the MAF hotwire with MAF cleaner.
You could also try Nyogel grease on the TPS connection.
Chicken_Lips
Re: faulty TPS
Postby Chicken_Lips » Sat Jan 23, 2016 1:10 pm
I'll just point you towards my thread.
Sounds very similar to my issue, nb8a also.
I am still learning and haven't tried everything suggested to me yet, due to work and house search priorities.
Does your issue go away once the engine completely warms up? I don't mean once the temp gauge hits halfway but after a good 10 minutes of driving.
I've got a couple of mates coming around some weekend soon to help me strip the entire intake and redo all the gaskets and clean the gunk out. I'll keep you posted.
zorak
Re: faulty TPS
Postby zorak » Sat Feb 06, 2016 11:13 am
So for those interested the problem was the 02 sensor.
Despite it being only 1 yr old I pulled it out and bench tested it. Turns out it wasn't working.
Replaced with a new one an now runs perfect again.
I guess disconnecting the TPS may have masked the problem as it would have just run in open loop and ignored the (faulty) 02 sensor?
...and another tip - be very careful cleaning the Hotwire on the maf i.e. dont touch it! I managed to snap mine off just lightly brushing it with a q tip.
NB8A
WP 1:10.69
SMSP (GP) 1:53.98
Chicken_Lips
Re: faulty TPS
Postby Chicken_Lips » Wed Feb 10, 2016 10:55 am
A good result. I've replaced mine and had no such luck, although it does run a bit smoother. Thanks for updating with your result.
