Cold and A/C idle issues and my attempts thus far
Posted: Sat Jan 16, 2016 5:06 pm
Hi folks,
I have a 92 NA6 with some idling issues.
My two main symptoms are;
- Low idle during cold start (about 500-600rpm, it will sometimes stall if I allow it)
- Lots of hesitation when moving off the line when cold, until about 2000 - 2500rpm
- Low idle with the A/C on
- Idle is fine at all other times
Here is what I have attempted so far;
- Reset base idle with TEN+GRND bridged (warm idle is now at a steady 850-900rpm with and without TEN+GRND bridged)
- Cleaned intake plenum
- Replaced air valve (though haven't tested it on the car yet as it hasn't had a chance to cool down yet)
- Ran the 'click test' on the ISC, which it failed (no click, idle speed did not change)
Based on all of this, especially the failed click test, it'd be safe to assume the ISC is at fault here, right? The only doubts I have is that it idles perfectly fine when warm with the AC off. Does that mean that the ISC is stuck closed?
There's also this miscellaneous plug coming off the thermostat that isn't attached to anything...should it be?
The only fault codes the car pulls are both related to the o2 sensor (that'll be replaced soon too).
