*Engine Swap* 2004 SE BP-4W into 2001 NB8B
AlexHaley1994
Postby AlexHaley1994 » Fri Nov 27, 2015 4:12 pm
Hi,
I recently purchased a turbocharged BP-4W which was removed from a written-off 2004 SE.
I plan on removing the current BP engine in my NB8B and swapping it with the BP-4W.
I have the wiring loom, ECU, exhaust, intercooler, manifold, and other associated parts from the SE.
I'll be replacing the engine mounts during the swap. My NB8B has the 6-speed box, so no worries about it not handling the power.
I'll be conducting the swap over Christmas.
Is there anything I should be aware of before I begin? Has anyone done this swap or one similar before?
Re: *Engine Swap* 2004 SE BP-4W into 2001 NB8B
Postby Mr Morlock » Fri Nov 27, 2015 5:39 pm
"Is there anything I should be aware of" - what you might want to check is legality and insurance.
Postby Lokiel » Fri Nov 27, 2015 6:20 pm
timk did exactly this swap on the car he just sold.
Do a search for his build thread to see what's needed.
cookie
Postby cookie » Fri Nov 27, 2015 9:13 pm
Being new and annoying you'll need the key / immobilizer I'd imagine.
lightyear
Infinity & Beyond
Postby lightyear » Fri Nov 27, 2015 10:20 pm
Why swap motors? The NB8B accepts the SE turbo and manifold. Has more compression, and seems to make more power than the SE motor. Unless your motor is shagged, I would just swap manifolds. Buy an MS3, and an EBay inter cooler. Look at my thread SE replica.
Postby Lokiel » Sat Nov 28, 2015 9:32 am
lightyear wrote:Why swap motors? The NB8B accepts the SE turbo and manifold. Has more compression, and seems to make more power than the SE motor. Unless your motor is shagged, I would just swap manifolds. Buy an MS3, and an EBay inter cooler. Look at my thread SE replica.
It's easier to get a RWC on a modded car with a turbocharger if the original engine came fitted with a turbo - that's one reason to do this.
cookie
Postby cookie » Sat Nov 28, 2015 10:28 am
Aside from a $100 mod plate the rwc is actually easier with the standard engine and la3 code clearly visible. Things to consider are oil drain on an se is standard etc.
project.r.racing
Postby project.r.racing » Sat Nov 28, 2015 12:01 pm
Except in this case both the engine numbers are related, so that issue wont arise.
AlexHaley1994
Postby AlexHaley1994 » Sun Nov 29, 2015 10:04 pm
Thanks for the advice guys :)
Users browsing this forum: No registered users and 52 guests
