CAS bolt came loose?
NicTheMx5
Postby NicTheMx5 » Mon Nov 09, 2015 1:13 am
I discovered the other day from when my car decided to drive funny on the way home, that the bolt on the back of the CAS was loose.
I'm assuming because of that, the sensor had moved around which would have affected my timing, and would explain the weird behaviour of the car on the way home. I've since tightened the bolt and mildly fixed my timing back to normal.
I'm wondering if this bolt is something that always comes loose from time to time in early mx5's?
Is there an easy way to prevent it from happening again?
NA6 TD05 :NA6:
project.r.racing
Re: CAS bolt came loose?
Postby project.r.racing » Mon Nov 09, 2015 10:06 am
locktight
