Nb8b,
Turn the headlights on and the revs drop 100rpm but do not rise.
Could anyone advise on this?
headlight idle
- Vehicle: NB Roadster
headlight idle
WINTON PB - 1:57.4000
- KevGoat
Re: headlight idle
Have you checked charging voltage before/after lights are switched on? Someone correct me if I'm wrong, but usual charge rate is around 13.7v (or slightly higher), if this drops below about 13v when lights are switched on there's an issue with the alternator or it's cabling. Could also be a loose belt, deteriorating earth ...
- bruce
- Vehicle: NA8 - Turbo
- Vehicle: Non MX-5
Re: headlight idle
dieing battery
dieing alternator
bad earthing
dead iac
dieing alternator
bad earthing
dead iac
Users browsing this forum: No registered users and 53 guests
