speedo cable - where is it?
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Oct 01, 2015 11:07 am
where does the speedo cable go in relation to the gearbox/under the car?
its for a 5 speed nb
bartmanftw
Re: speedo cable - where is it?
Postby bartmanftw » Thu Oct 01, 2015 12:49 pm
It doesn't have a speedo cable.
16bit
Postby 16bit » Thu Oct 01, 2015 1:32 pm
balls.
why might my speedo be not working after a clutch install do you think?
Postby hks_kansei » Thu Oct 01, 2015 1:36 pm
Sender is on the top right of the gearbox from memory.
As for the cable, the NA used a mechanical cable from the sender
on the NB the speedo sender was electronic and simply had electrical wires leading up.
16bit
Postby 16bit » Thu Oct 01, 2015 2:34 pm
so can i get to it from the turret in the cabin or do I need to get under the car?
Roadrunner
coyotes after you
Postby Roadrunner » Thu Oct 01, 2015 3:39 pm
You can only get to it from under the car.
The sensor is sticking out the drivers side of the gearbox.
See here about half way down the page:
viewtopic.php?f=57&t=62536&start=30
If you need to remove it jack the car up really high from the rear and you wont spill any gearbox oil.
Its above the exhaust too so even with the bracing removed its still tight to get too.
Hopefully your issue is the cable was just forgotten to be plugged back in.
MeepMeep
16bit
Postby 16bit » Thu Oct 01, 2015 5:17 pm
i might just take it back to him and get him to do it.
in the mean time free km's!
Postby hks_kansei » Thu Oct 01, 2015 6:21 pm
As above, it's an under car job.
Most likely he's just forgotten to plug it back in, which can be done without removing anyhting from memory.
it's just a spade connector on the back on the sender, so just presses on.
Nearby will also be a pair of bullet connectors for the reverse light switch, might be worth checking they're plugged in too.
edit:
Thinking a bit harder, you should see the plug near the PPF, the wires clip onto the PPF so that if the wires are unplugged it wont hang down and drag on the road.
project.r.racing
Postby project.r.racing » Sat Oct 03, 2015 9:40 am
either it wasn't plugged back in. or worst case scenerio, he dropped the gearbox with it still attached.
16bit
Postby 16bit » Sun Oct 04, 2015 10:16 pm
i am going to have him fix it next week.
thanks everyone. greatly appreciated!!
