Valve cover breather help needed
mx589
Postby mx589 » Tue Sep 15, 2015 7:22 pm
Hey guys on the NB 1.8 valve cover the breather pipe near the oil cap is it just a press fit?
Can it just be pulled out ?
Or does the valve cover have to be removed to tap it out ?
Re: Valve cover breather help needed
Postby hks_kansei » Tue Sep 15, 2015 8:36 pm
PCV is press in, the rubber grommet stays in the cover.
Breather on passenger side has a welded in barbed fitting, the hose just presses on.
mx589
Postby mx589 » Tue Sep 15, 2015 9:14 pm
Yeah the breather on the passenger side steel one that the rubber hose goes onto.
So set of mto grips pliers you can't just pull it out ?
Postby hks_kansei » Tue Sep 15, 2015 9:35 pm
Pretty sure it's either welded or interference fit.
Either way, not likely to come out without destroying it.
if It were me i'd just cut it off flush and then plug the hole or hammer in a new fitting if needed.
mx589
Postby mx589 » Tue Sep 15, 2015 10:57 pm
Will check it out see how I go
Thanks for the info
Users browsing this forum: Google [Bot] and 2 guests
