Clutch Slave Cylinders..... Genuine or Aftermarket?
Venuci
Postby Venuci » Wed Sep 09, 2015 4:55 pm
Hi Everyone
Quick question for all you wise heads on this forum.....
Talking about the clutch slave cylinder on an NA6 - has anyone found any difference (either in the operation or longevity of the part) between the genuine Mazda article or an aftermarket alternative brand such as Protex?
Ven
project.r.racing
Re: Clutch Slave Cylinders..... Genuine or Aftermarket?
Postby project.r.racing » Wed Sep 09, 2015 5:38 pm
Most genuine stuff is just repackaged aftermarket stuff. I'm doubtful MAzda has made a slave cylinder for a 25yo car for the past 15 years.
p.s. Genuine or aftermarket, it is all the same.
zossy1
Postby zossy1 » Wed Sep 09, 2015 6:25 pm
They are all equally fragile.
Postby hks_kansei » Wed Sep 09, 2015 6:27 pm
As above, most of it's the same anyway.
I know Mazda used to have their brake parts made by PBR, so maybe look for a PBR one if you're really concerned.
bear2230
Postby bear2230 » Wed Sep 09, 2015 9:50 pm
I have Protex in both cars. Funnily enough the originals both went within a month of each over.
One car had 45K the other 180K km's.
Bought one from MX5+ the other from Bursons about $70.00 each I think.
You can get them from the states for $15.00
Postby manga_blue » Thu Sep 10, 2015 8:00 pm
bear2230 wrote:I have Protex in both cars. Funnily enough the originals both went within a month of each over.
Master and slave cylinders often expire at about the same time on one car. I'd be inclined to do both in one job. Aftermarket is fine - aim for $70 for the master and $40 for the slave.
Venuci
Postby Venuci » Tue Sep 15, 2015 9:15 am
Hi Everyone
Thanks to all of you who added some wisdom and advise to this thread - you are all amazing! :)
Ven
Steampunk
Postby Steampunk » Tue Sep 15, 2015 9:55 am
I set up a group buy for Daikin units many years ago and they were fine. I believe Daikin is OEM manufacturer for quite a number of components.
wun911
Postby wun911 » Tue Sep 22, 2015 9:05 pm
I still have that installed about 80,000 km still going strong. Bleed it every time I bleed breaks maybe once a year.
every ounce counts
