hi flow cats
hi flow cats
Hey guys I've recently got the headers and catback of my exhaust done but have read about members recommending to replace the old cat with a hi flow cat as they're usually buggered. Given that my car has done 190,000 kms I figured this would be a good idea. Just wondering if there would be a difference to sound (I dont want a raspy noise but I would love a volume increase if possible), and a performance gain. Perhaps a 200 cel cat or a 100 cel cat would help increase the sound ? Any recommended brands, seems like xforce or magnaflow are the general choice. Thanks !
Re: hi flow cats
THere's a sound increase, but it's only slight,
The note changes a bit more.
Currently I have a 50 or 80-cel cat on mine (cant remember) and OEM everything else, only the tiniest bit louder than stock (seriously you'd not pick it) but it does sound a little dirtier, less smooth.
My old setup had a straight thoughm muffler and the cat made that npticably louder, and a lot rougher sounding, also shot a little flame occationally.
Re: hi flow cats
hks_kansei wrote:Currently I have a 50 or 80-cel cat on mine (cant remember) and OEM everything else, only the tiniest bit louder than stock (seriously you'd not pick it) but it does sound a little dirtier, less smooth.
Wow that 50/80 cell cat must be pretty hi flow.
My car with no cat used to shoot a flame out the exhaust on overrun (thanks to crappy installer tune) however once I fitted a 200cell cat it arrested the flame, so that only smoke puffed out.
Re: hi flow cats
It's only very rarely that it would pop a flame, and would only do it after me having given the car a lot of stick for a decent timeframe (so everything was well and truely hot)
I don't actually know what the cell count is, I bought it secondhand but the guy I got it from said it was a 50 or an 80 (I forget which he said)
I know though that you can see through it pretty easily, each cell was like a macdonalds thickshake straw.
TBH though, I felt no power change once it was fitted, it was all just noise (which really describes my car on the whole)
Re: hi flow cats
Thanks for the info, seems like a 200 cel cat is the way to go..any increase in sound is worth it !
Re: hi flow cats
any recommended brands without breaking the bank ? I suppose they're all quite similar in performance so I guess i'd be looking at sound. The metal cats seem interesting but out of my range seeing as they go for 200+
- Vehicle: Non MX-5
Re: hi flow cats
when i installed my cat, it increased the sound quite a lot. i had a similar system to yours, and did the cat last/separately.
Re: hi flow cats
In what way was it increased? More raspier or a more aggressive note or the same exhaust note but the loudness being emphasised? Also what cat is it that you are running ? Cheers !
project.r.racing wrote:when i installed my cat, it increased the sound quite a lot. i had a similar system to yours, and did the cat last/separately.
Re: hi flow cats
Cats tend not to increase power unless it is the bottleneck in the system, Ie reducing flow.
Currently my cat is a bottleneck but I may not be able to pass the EPA test if I go for a high flow
So it stays for now.
- Vehicle: Non MX-5
Re: hi flow cats
raspieness tend to come from a poor designed and flowing big exhaust. ie axles backs etc. exhaust made up of different pipe diameters and flows.Roadster2 wrote:In what way was it increased? More raspier or a more aggressive note or the same exhaust note but the loudness being emphasised? Also what cat is it that you are running ? Cheers !project.r.racing wrote:when i installed my cat, it increased the sound quite a lot. i had a similar system to yours, and did the cat last/separately.
i got same exhaust note, but 20%ish louder.
i forget now what my cat was, thinking 100 or 150 commodore 2.25" version. shop said do this, cheaper option that performance brands but does same job. it worked.
Re: hi flow cats
what is the diff between having liek for eg 200 cell or 400 cell? I couldnt find any info on this before buying a new cat, so i just went with a 400 cell one.
I found it weird after installing new genie performance headers + cat that no difference was made in terms of sound? After I drove off out of the exhaust shop, I was quite confused, as I was expecting a louder roar once these were installed.
- Black_Penguin
Re: hi flow cats
Extractors are more likely to change the character of the exhaust note rather than the volume and a hi flow cat would make minimal compared to the rest of the exhaust system.
Re: hi flow cats
I dont think I noticed much of a sound difference after the installation of headers. Perhaps slightly more boomy if at all. I'm still contemplating between a 200cell metal cat vs a ceramic cat, just not sure which one will put out less rasp on my exhaust system.
