Hi guys,
I am in he process of rebuilding my BP4W, it is back in the car and it should be running again in the next week or so.
I am going to use Castrol GTX 10W30 for the break in period then switch back to Castrol Edge synthetic after. Prior to the rebuild, I was using the Castrol Edge 10W60 and made sure I thoroughly warmed the engine up prior to driving.
My question is, what viscosity oil is best suited to a freshly rebuilt engine, warm Perth weather and the engine does get a fairly hard time with a turbo hanging off the side. The car is not a daily driver so I don't need an oil where I can start and instantly go.
Thanks,
Dale
BP4W rebuild - oil suggestions?
- wydra
- Vehicle: NB8A - Turbo
NB8A - GT2560R, DIYPNP MS2
zoom zoom boom
zoom zoom boom
Re: BP4W rebuild - oil suggestions?
You could use a purpose run in oil for the first 500km then drop it (and the filter) and replace with your chosen oil.
- Vehicle: 10AE - Turbo
Royal Purple make a mineral running in oil.
10AE
WP 1:04.7 SMSP GP 1:43.0 South 1:00.8 North 1:09.8
Otherwise any fairly plain dyno oil should do. Avoid synthetics for run-in, they're too slippery and can lead to glazing. Castrol RX diesel oil is popular.
- wydra
Maybe I confused people.
For initial startup and break in I will be using Castrol GTX 10W30 dino oil.
After the break in period, I will swap back over to Synthetic oil. I am interested in what viscosity oil people recommend AFTER the break in period.
zoom zoom boom
zoom zoom boom
I'm running Castrol Edge 10W-60 in my track car. I do a combination of sprints, track events etc so it's sometimes hard to get the engine at full operating temp.
So far so good.
So far so good.
HKS Super Racing 10w55
Max. Oil Temp. 150℃
100% SYNTHETIC
SM-CF equivalent
It is road registered but does very few road KM's.
Max. Oil Temp. 150℃
100% SYNTHETIC
SM-CF equivalent
I just use 10w40.
Brand is whatever's on special when I buy it, and isn't "black and gold"
- wydra
The engine has started and is being run in with dino Castrol GTX 10W-30.
So far so good with no strange noises and everything sounding sweet.
After about a 500km run in, I will switch over to fully Synthetic oil, I have it down to either Castrol Edge 0W-40 or 10W-60.
Does anyone have any experience with a rebuilt engine (forged rods/pistons, rebored and all new bearings) with a turbo in a warm climate? In the past I have used the 10W-60 and it seemed to work great, but now the engine has been freshened, maybe the 0W-40 might be better? or just stick with 10W-60?
zoom zoom boom
zoom zoom boom
Mine is not turbo but was honed and re-ringed and I wring the neck off it on every gear change. 700km break-in with some high-pressure pulls up hills to seat the rings. Since then I've used a mix of good 10W40s and 10W50s and it's lasted 3,000 competition laps, including stinking hot days, and maintained full compression. I don't think they're that fussy about viscosity. Just buy good stuff.
