Where is the Fuel tank drain plug (1990 NA)
randyMX5 ImBack
Postby randyMX5 ImBack » Sun Aug 09, 2015 6:26 pm
As per subject heading, I was wondering where the fuel tank drain plug is for a 1990 NA MX5.
Thanks in anticipation
Randall
randyMX5 ImBack
Re: Where is the Fuel tank drain plug (1990 NA)
Postby randyMX5 ImBack » Mon Aug 10, 2015 11:22 am
I should also ask: Do all MX5 NA tanks have a drain plug? The reason I ask is because I would expect it at the lowest point of the tank but I cannt see one there..
Any help would be appreciated
Thanks again
Randall
Postby 93_Clubman » Mon Aug 10, 2015 12:33 pm
From memory there's not a drain plug as such, ie a removable plug at/near the lowest point of the tank.
randyMX5 ImBack
Postby randyMX5 ImBack » Mon Aug 10, 2015 1:31 pm
93_Clubman wrote:From memory there's not a drain plug as such, ie a removable plug at/near the lowest point of the tank.
THANKS
Make perfect sense.. I can stop looking before I go mad
That said how do people drain their fuel?
madjak
Postby madjak » Mon Aug 10, 2015 2:10 pm
Disconnect the fuel line off the metal fuel line in the engine bay, connect a longer line and run it to a jerrycan and sit in the car turning the ignition on and off. Doesn't take too long but can drain the battery a bit.
Alternatively you can take out the fuel pump and siphon it directly out of the tank.
edit: the rearmost hardline is the feed line too... not the front one.
mx589
Postby mx589 » Thu Aug 13, 2015 1:02 am
No drain plug on na or nb
Postby Magpie » Thu Aug 13, 2015 4:34 pm
You can always disconnect the fuel filter underneath the car. Instead of turning the car on an off you can jumper the fuel pump to run with the ignition on.
This is my change fuel setup, thanks to Jason at MX5 Plus. An AN fitting with a length of hose, jumper the fuel pump and collect in jerry can.
ImageDSCN2651 by Eipeip, on Flickr
ImageDSCN2654 by Eipeip, on Flickr
ImageDSCN2653 by Eipeip, on Flickr
