NA6 diff noise
Posted: Fri May 08, 2015 9:52 pm
I have attempted to upload a sound file, in both M4A and MP3 formats. Both were rejected 'The extension MP3 (M4A) is not allowed'.
I was hoping someone had heard this noise before, and was able to fix, without replacing the diff, but until I can find an acceptable sound file format for this forum, I guess my description of sounds like a 'whistling noise' will have to do.
The car is a
1991 Eunos, imported by the owner from Japan. It has travelled, not counting the trip from the land of the rising sun, 166k, 30k of which are down to me. The diff oil was changed out at 150k using Penrite 75W90. The noise started three days ago, once the car has reached normal operating temp (about 4-5km). The diff is not hot, and the oil level when checked tonight is sitting just under the fill plug. When a rear wheel is turned, and the car is in neutral, its partner turns in the same direction, so I am assuming this is a VLSD.
I recorded the whistling noise after taking it for a drive to warm up, then placing it on stands and running in 4th gear at idle. The noise appears to be coming from the pivot (ie diff input shaft).
Any ideas please? And if someone can advise what sound file formats are permitted I can upload the 'real' sound.
The car is a
