Hey guys
So my na6 won't idle... or If It does, it will sit on about 200rpm
Revs freely through the rev range but I have to keep my foot on the throttle or it will just stall and previously my car would hate cold starts, it Would do The opposite of what its meant to do, it would idle at about 500 when cold then slowly climb to 8-900 as It warms up but now it wont idle even when warm.
I was thinking maybe the green water temp sensor ?
or maybe ignition leads or coil pack ?
any help is appreciated
na6 wont idle
Re: na6 wont idle
Stretched throttle cable?
Does the car have a stock ECU? Are there any engine mods?
- Learner Driver
Re: na6 wont idle
only an intake installed by the previous owner that appears to be intact with no cracks
how could a stretched throttle cable cause this ?
- Learner Driver
Re: na6 wont idle
Throttle cable is fine and reset idle last week
Re: na6 wont idle
lowwn wrote:So my na6 won't idle... or If It does, it will sit on about 200rpm
Could be a number of things - if it was just a cold start issue, as it was earlier below, then yes the green water temp sensor. And that could still be part of the problem, but it now seems like there's more. You really need to baseline service the car so that you have more of a known quantity to deal with, otherwise it's a scattered approach, which might eventually identify the problem, but could be over a long period of time.
Na6 running rich ??
lowwn wrote:On cold starts, it starts a little rough and idles at about 650 - 700rpm untill it warms up then idles at 800 - 1000 and sometimes there is a bit of hesitation low when driving it a bit too cold.
I'm probably going to change o2 sensors, clean afm, change plugs and leads and have a look at the injectors
viewtopic.php?f=29&t=67047
